Disable Special Keys Feature Not Available in LabVIEW
Updated Sep 10, 2018
I'm trying to use the Disable Special Keys option (Tools>>Options>>Security) from LabVIEW but it is not available.
How can activate it?
To use the Disable special keys option you should install the NI Keyboard Filter Driver following the steps below:
1. Consider that the NI Keyboard Filter Driver is only compatible with Windows 32-bit OS.
2. Download the Datalogging and Supervisory Control (DSC) Module. The latest version is available here.
3. Open the installer and go to:
Products\LabVIEW_DSC_KeyboardFilterDriver\LVDSC.kbFilter.850
4. Open the kbFilter.msi file and complete the software installation.
5. Reboot your computer and relaunch LabVIEW.
If you are using LabVIEW with other OS (different from Windows 32-bit) you can programmatically disable the key using the method suggested in Programmatically Disable Functioning of a Keyboard Key in LabVIEW.
