- In Windows, create a folder that you wish to share. For example, C:\Data.
- Share the folder. Make sure that a user has RW permission to the folder.
- Connect to Linux RT shell (make sure SSH is enabled for controller in NI MAX). Putty is a good SSH client.
- Log in to root.
- Create a data folder to map to the network shared folder in /home/lvuser:
mkdir /home/lvuser/data
- Mount network shared folder to the folder you just created. UID=lvuser gives lvuser RW permission to the folder.
mount -t cifs //[IP of remote server]/[name of shared folder]/ -o username=[your username],password=[your password],uid=lvuser /home/lvuser/data
- You should now be able to log data to the /home/lvuser/data folder from LabVIEW.
