cRIO and sbRIO Changing Module Programming Mode in MAX
Updated May 12, 2025
  • cRIO-9040
  • cRIO-9041
  • cRIO-9042
  • cRIO-9043
  • cRIO-9045
  • cRIO-9046
  • cRIO-9047
  • cRIO-9048
  • cRIO-9049
  • NI CompactRIO
What software do I need to have installed on my computer to be able to change the programming mode of modules in cRIO-904x, cRIO-905x, sbRIO-960x, sbRIO-9628, sbRIO-9627 or sbRIO-9638 chassis between Real-Time (NI-DAQmx), Real-Time Scan (IO Variables), and LabVIEW FPGA?
In order to change the programming mode of the modules in your CompactRIO or sbRIO with NI-DAQmx (cRIO-904x, cRIO-905x, sbRIO-960x, sbRIO-9628, sbRIO-9627 and sbRIO-9638 series), refer to the getting started guide for your specific controller on what software you will need. Once you have the proper software installed for your application, you can follow the steps further down to change the programming mode.
