2-Wire 32x1 Topology in PXI 2527 Connects com0+ to com1+ and com0- to com1-
Updated Aug 8, 2019
  • PXI-2527
  • PXIe-2527
  • NI-SWITCH
I have an application that requires me to change topologies from 4-wire 16x1 Mux to 2-wire 32x1 Mux for a PXI 2527 Multiplexer Switch Module. When changing the topology, the com0+ and com 1+ channels are connected and the com0- and com1- channels are connected.
This is an expected behavior due to the Multiplexer Switch Module layout. To allow the Multiplexer Switch Module to have a 2-wire 32x1 Mux topology, it internally connects both individual multiplexers in the 2-wire Dual 16x1 common channels. You can use the 2-wire Dual 16x1 topology to prevent the channels from being connected.
You can consult the NI Switches Help to consult the different topologies this Multiplexer Switch Module supports.
