Programmatically Set Filename For Logging in VeriStand
Updated Aug 13, 2018
  • VeriStand
I am logging data in the VeriStand Stimulus Profile Editor. I would like to set the filepath dynamically based on operator inputs in LabVIEW. Can I do this?
Yes, you can access the filepath and filename of the log generated in your Stimulus Profile Editor by calling into the VeriStand .NET API in LabVIEW. These filepaths can be accessed by .NET Constructor Nodes, as seen in the VI attached to this article.
Note: The attached VI is not fully functional, but should serve to act as an example of how to access these properties from the VeriStand API in LabVIEW.
