Support for compactRIO depends on whether you are using the PROFIBUS module as a slave or a master as given below. Note that the information in this article is applicable for 4.0.1.2 version of
cRIO PB Master/Slave driver and 4.0.0.2 version of
cRIO PB Slave driver.
Using PROFIBUS Module as a MasterIf you're using the module in the master mode, then the following compactRIO models are supported.
CompactRIO Controllers| cRIO-903x | cRIO-904x | cRIO-906x | cRIO-907x | cRIO-908x |
| cRIO-9030 | cRIO-9040 | cRIO-9063 | cRIO-9073 | cRIO-9081 |
| cRIO-9031 | cRIO-9041 | cRIO-9064 | cRIO-9074 | cRIO-9082 |
| cRIO-9033 | cRIO-9042 | cRIO-9065 | cRIO-9075 | |
| cRIO-9034 | cRIO-9043 | cRIO-9066 | cRIO-9076 | |
| cRIO-9035 | cRIO-9045 | cRIO-9067 | | |
| cRIO-9036 | cRIO-9046 | cRIO-9068 | | |
| cRIO-9038 | cRIO-9047 | | | |
| cRIO-9039 | cRIO-9048 | | | |
| | cRIO-9049 | | | |
CompactRIO Chassis| NI-910x | NI-911x | NI-914x | NI-915x |
| NI-9101 | NI-9111 | NI-9146 | NI-9154 |
| NI-9102 | NI-9112 | NI-9147 | NI-9155 |
| NI-9103 | NI-9116 | NI-9148 | NI-9157 |
| NI-9104 | NI-9118 | NI-9149 | NI-9159 |
Using PROFIBUS Module As a Slave
When your module is used as a slave, the following compactRIO models can be used.
- CompactRIO Controllers - cRIO-903x, cRIO-904x, cRIO-905x, cRIO-906x, cRIO-907x, cRIO-908x
- CompactRIO Chassis - cRIO-910x, cRIO-911x, cRIO-914x, cRIO-915x
