For Loop Pre-Expression Grayed Out in TestStand
Updated Aug 3, 2018
  • TestStand
When I create a For Loop and try to write a Pre-Expression for it, the Pre-Expression field is grayed out. How can I set a condition under which the For Loop will be entered?
Setting a Pre-Expression for a For Loop is a disabled function. Instead of using this approach, you can include the For Loop in an If Structure. This way, each time the loop is iterated the program will check that the condition is met.
