Incorrect Login Information Error When Doing Remote File Transfer from NI MAX
Updated Aug 2, 2018
  • cDAQ-9137
  • PXI-8106
When I use the NI MAX file transfer function on my real time target, a window in my browser opens asking for a username and password. When I use the login information that I use to configure the device in NI MAX, I get an error that says I do not have the correct login information. What should I do?
If you encounter this error, ensure that you are using the correct login information and that you have not mis-typed anything in the username or password. Also ensure that your username is not "admin" (default) and that your password is neither "admin" or blank (default).
