How Do I Access Each Index Number of an Array?
Updated Jan 7, 2020
How do I access each index of my array so I can perform different data operations depending on the index?
  1. Create a for loop
  2. Create a case structure inside of the for loop
  3. Wire the array to the for loop
  4. Right-click the tunnel and select "Enable Indexing"
  5. Wire the tunnel to the case structure
  6. Create cases for each index of the array
