Removing Guarding Pins in SMU Cables
Updated Oct 3, 2018
  • PXI Source Measure Unit
Are the guard pins of my SMU really needed? What happens if I avoid using them with a custom cable?
The guard pins are needed to prevent leakage currents and parasitic capacitances. (i.e pings 1, 4, 7, 10 in a PXIe-4140).
Although you might not use them, it's possible that the accuracy specifications of your device canĀ“t be met without them.
Guarding is specially important in low voltage measurements. Although cable insulation impedance is typically high, it can have a significant effect when measuring small currents from high-impedance loads.
You can find a list of the SMUs that support guarding in Related Links.
