This behavior typically occurs when your agreement uses an Unmanaged (Concurrent) license or if you're trying to create a license group under the wrong license type.
Unmanaged licenses:
- Are not tied to specific users or computers
- Do not require permission assignment in VLM
- Allow any client machine to check out a license as long as it can connect to the server
VLM does not allow these licenses to be assigned to groups, so they will not appear in the Add License list. This is expected behavior and not an error.
To create a license group, you must have a license that matches the selected license type. For example, if you attempt to create a User Group but only have computer‑based licenses, the License Name field will appear empty.
