Purpose of CFast Card on TPC-2230
Updated Sep 27, 2018
There is a CFast card that plugs into the side of the TPC-2230. Is that the hard drive?
Yes, the CFast card contains the Windows OS for the TPC-2230. You can find this information and other details in the TPC-2230 User Manual.
If you are having trouble loading your Windows OS or installing from the Recovery USB, your CFast card may not be securely inserted in your TPC-2230. If the card is loose, you may have installation errors.
