Deploying TestStand Sequence Shows Errors Related to the LabVIEW VIs That Are Being Called
Updated Aug 7, 2018
  • LabVIEW Run-Time Engine
  • TestStand
I am trying to deploy a TestStand application that calls code modules and that is called from a LabVIEW User Interface but I am receiving errors linked to the VIs that are being called.
The LabVIEW VIs need to be compiled before deploying them on another computer that only has the LabVIEW Run-Time Engine installed. You can use library files for this purpose, following the steps in the article How Do I Create a Library File (LLB) in LabVIEW?
After creating the libraries, you just have to change the path in TestStand to point to the VI on the Library instead of the original VI.
