Maximum Sampling Rate for the NI-9211
Updated Apr 24, 2023
  • NI-9211
What is the maximum sampling rate for the NI-9211, USB-9211 and USB-9211A, and how is it affected by the CJC and autozero channels?
When performing a thermocouple task, the NI-9211 automatically reads both the cold-junction and autozero channel values and uses them to calculate the temperature every time the scan list is sampled. Both reads count towards the overall sample rate.
Below is a table that shows maximum allowable sample rates for the NI-9211 in Hz.
Higher sample rates might be obtained by reading the desired thermocouple channel as a voltage channel in an Analog Input task. However, as an Analog Input task, the resulting units are volts, and temperature calculation is not performed by the driver.
The cold-junction compensation sensor can be read using physical channel 4 as a voltage channel. The autozero channel is not available as a physical channel.
