Error -1074097852 When Trying to Control a DMM Card?
Updated Dec 16, 2018
  • PXI-4065
  • NI-DMM
I want to control PXI 4065 with LabVIEW panel. However, an error shows that "Error -1074097852  Possible reason(s): Resource requested by this task has already been reserved by a different task." The card can be recognized and the output can be read in NI-MAX.
The reason for this error is: you cannot control the DMM card with LabVIEW and soft panel simultaneously. As the DMM soft panel has occupied the resource so the LabVIEW cannot access it.
To solve this problem, you should close the DMM soft panel before opening LabVIEW.
