Does InstrumentStudio Support Temperature Measurements for DMM's?
Updated Aug 31, 2018
  • DMM Probe
  • InstrumentStudio
I am trying to take simple temperature measurements in InstrumentStudio with a digital multimeter (DMM) but I can't find where to do so. I know this feature was available in the old DMM Soft Front Panel. Is there no way to take temperature measurements in InstrumentStudio?
There is no feature in InstrumentStudio to take temperature measurements as there was in the DMM Soft Front Panel. You can request that such a feature be added by using feedback tool found in the top right hand side of the UI.
You can also continue using the DMM Soft Front Panel to take temperature measurements after installing InstrumentStudio. Installing InstrumentStudio does not remove the DMM Soft Front Panel, but in order to access it you will need to manually open the Soft Front Panel .exe file found in the directory where it was installed.
If you are using a 64-bit Windows operating system this can be found at: C:\Program Files (x86)\IVI Foundation\IVI\Drivers\niDMM\NI-DMM Soft Front Panel.exe
If you are using a 32-bit Windows operating system this can be found at: C:\Program Files\IVI Foundation\IVI\Drivers\niDMM\NI-DMM Soft Front Panel.exe
