Can I Use My Digital I/O Device to Power My Sensor?
Updated Sep 18, 2018
  • Digital I/O Device
I am using one of National Instruments Digital I/O device in my application. Can I use that to power my sensor?
You can check the Specifications and/or Datasheet to make sure that it has the appropriate output requirements. Check the documentation to see what requirements or settings need to be implemented in order to use them for your application.
Not all Digital I/O devices have the same specifications.
