AKD Drives Disconnect with Fault 502
Updated Oct 4, 2018
  • CompactRIO Chassis
  • Kollmorgen Drive and Motor Cable
  • LabVIEW SoftMotion Module
After running my SoftMotion code, I notice that my AKD Drive disconnects after 5 to 30 seconds with Fault 502.
This behavior can be caused by the Scan Engine running late. Check the Distributed System Manager for fault 66460 on the CompactRIO. Use Set Scan Engine Period VI to increase the Scan Engine period.
