Can I Average Measurements from the Hardware Side to Avoid Getting Noisy Signals on My cDAQ-6341?
Updated Oct 27, 2018
  • USB-6341
I want to increase accuracy and reduce noise from my input signals. Can I do it from the hardware side of my cDAQ-6341?
Unfortunately, from a hardware perspective, averaging signals is not possible. Input signals are already conditioned to be used in different applications and if you want to average your measurements; you can do it by programming your application.
The following code snipet show a quick way of averaging the number of samples measured by your device.
