How To Convert XML or ATML to TDMS File
Updated Aug 15, 2018
  • DIAdem
I want to convert an XML or ATML file to a TDMS file to be able to analyze the data acquired with DIAdem.
A VI was developed to make this conversion from XML or ATML to TDMS.
1.-First is necessary to install the ATML_5 DataPlugin.
2.-Download the Zip File attached and open the Project
3.-Open the VI Read ATML File and follow the instructions before run.
This VI is not fully optimized to work with too many files at the same time. The VI has been tested it with 4 files at the same (Another factor to take into account is the amount of data contained on each file)
Use this as an example to develop a program capable to handle the required files you need to convert.
