Getting Error -2147220623 When Reading Largest Memory Block on CompactRIO
Updated Aug 7, 2018
  • CompactRIO Controller
  • cRIO-9067
  • NI Linux Real-Time
  • VxWorks
  • PharLap
I get Error -2147220623 from System Session Property node when running the following code on cRIO-9067.
Why do I get this error?
Largest Memory Block Property is applicable for CompactRIO running VxWorks or PharLAP Operating System.
As cRIO-9067 is running NI Linux Real-Time OS, Error-2147220623(The property does not exist for this resource) occurs.
See Link Below to see how to monitor memory usage in NI Linux Real-Time OS.
Memory Reporting Issue with NI Linux Real Time OS Target
For OS information of CompactRIO see the related link below.
