LabVIEW Boolean Array To Number only Returns U32
Updated Jul 25, 2018
I want to typecast a boolean array of 64 elements. I am using the Boolean Array to Number function but the result is an Unsigned 32-bit Integer (U32). How do I get a U64?
The Boolean Array to Number function returns a U32 by default. You can change the representation by Right-Clicking the Boolean Array to Number function >> Propertes >> Output Configuration tab >> Left-Click the image under Representation >> Left-Click on your desired representation >> OK.
