Actor Framework Stop Core VI Corrupt or Broken
Updated Jul 25, 2018
I have an issue with the Stop Core VI in actor framework. The Stop Core VI behaves as if it is not part of the Actor class
To resolve this, perform the following steps:
1. Close all project and exit LabVIEW
2. Open Actor Framework.lvlib
3. Remove Stop Core.vi from Actor.lvclass
4. Open Stop Core.vi.
5. Add Stop Core to Actor.lvclass by dragging Stop Core's icon into the library (you must drag the icon; other methods won't work)
6. Stop Core should no longer be broken
7. Give Stop Core protected scope
8. Perform a Save All for this class
This is a known issue and is discussed in depth on our community forum here: Stop Core vi broken
