Use the NI Example Finder to browse or search examples installed on your computer. These examples demonstrate how to use LabVIEW to perform a wide variety of test, measurement, control, and design tasks. Select
Help » Find Examples or click the Find Examples link in the Examples section of the Getting Started window to launch the NI Example Finder.You can easily access NI Example Finder by doing the following:
1. While opening LabVIEW, Click
Help on the menu bar (you can find it on the project explorer, front panel or block diagram)
then Click on
Find Examples
2. A new window named NI Example Finder would show
3. Click on
No Hardware Chosen>>
Add Device
4. Select the specific Device that you want to work with from the Dialog box and click on the
Right Arrow
5. In the NI Example Finder Dialog Box, select the specific Device from the Dropdown and select the option
Limit Results to Hardware. Now you shall only the examples relevant to the Hardware that you have chosen.
Always create a copy by saving as the examples to another name to avoid overwriting the original example VIs.
Please note that some certain set of examples won't be listed in the NI Example Finder, for example NI-USRP several example applications are only accessible by opening from the following locations:
- From the Start menu at Start»All Programs»National Instruments»NI-USRP»Examples.
- From the LabVIEW Functions palette at Instrument I/O»Instrument Drivers»NI-USRP»Examples.
You may also find examples on our website by accessing
ni.com/examples
