Left Camera Does Not Work in Calibrate Stereo Vision System
Updated Jul 23, 2018
  • Vision Development Module
I am using the “Calibrate Stereo Vision System.vi” to calibrate my stereo vision configuration. However, the left camera will not calibrate correctly. Specifically, the left calibration grids will all read “NaN” as opposed to a numeric value. How can I fix this?
This is a known issue documented in corrective action request (CAR) #583183. As a workaround, you can force the execution order of functions in the Stereo - Calibration Manager.vi subVI. Modify the Init case of the VI to match the following block diagram.
