Error -61488 When Compiling LabVIEW FPGA Code Remotely
Updated Aug 17, 2018
  • LabVIEW FPGA Compile Cloud Service
I'm compiling my LabVIEW FPGA code on a remote system (either LabVIEW FPGA Cloud Compile Service or on a remote compile server). After the intermediary files are generated, I see that my compilation has failed with errors.
When I click on "Details" to find more information, I see the following:
What is causing this issue, and how can I compile my code successfully?
When you see this particular compilation error, it could mean several things. The most common solutions to this behavior are:
  • Uncheck the "Remember Password" option in the "Configure.." window
  • Remove any special characters in your password
  • Force Reinstall the LabVIEW FPGA module
If you have attempted these solutions and are still seeing the error, please contact National Instruments Support for more assistance.
