If LabVIEW Run-Time Engine is not being installed correctly:
Ensure that the user account you are logged into has administrative privileges. This will allow for proper installation of all the drivers/associated files.
If the Installer is still not functioning properly right click the Installer and select "Run As Administrator".
If receiving an error that states "Unable to locate LabVIEW Run-Time Engine":
You may have an incorrect version of LabVIEW Run-Time Engine for your application.
To run a LabVIEW Application, the version of LabVIEW Run-Time Engine in the Installer must be the same version as the LabVIEW Development Environment that was used to create the Application.
Alternatively, Applications created in LabVIEW 2017 or newer can be configured to run with newer versions of LabVIEW Run-Time Engine. This setting can be enabled in the Advanced tab of the Application Properties window, as shown:
Note that this option is not available for Applications created in LabVIEW 2016 and older.
