The solution depends on whether you are using a National Instruments USB device or third-party USB Test and Measurement hardware.National Instrument USB HardwareIf using a National Instruments device, the application is launched by the NI Device Monitor. Refer to Disable the NI Device Monitor Popup with USB Devices to learn how to avoid the NI Device Monitor from displaying the message or executing at all.For USB Test and Measurement Devices (Windows 7 Only):
A valid service agreement may be required, and support options vary by country.
