Can I Connect an Ethernet Switch to an NI Frame Grabber?
Updated Jul 30, 2018
  • Frame Grabber Device
  • PCIe-8237
I have an NI Frame Grabber, such as the  PCIe-8237R, can I use an Ethernet switch and connect 2-4 cameras?
Yes, you can use an Ethernet switch. However, your bandwidth will be split between the cameras and you may need to lower the frame rate.
