Error -200077 When Trying to Set V/V as the Pre-Scaled Value on a Custom Scale
Updated Aug 20, 2018
  • NI-9237
I am trying to acquire pressure measurements using an NI-9237  strain/bridge input module with a custom scale. LabVIEW is giving me an error saying that only psi are accepted as pre-scaled values and it does not accept V/V.
This module is already making the conversion from V/V to pressure internally so it does not require to use a custom scale for this purpose.
A custom scale can be used to change from one pressure unit to another one.
