Can I Use My New C Series Modules with My LabVIEW Real-Time Version?
Updated Aug 31, 2018
  • LabVIEW Real-Time Module
  • NI-RIO
I am using LabVIEW Real-Time Module. I have put together a cRIO System configuration I am planning to buy, but I am not sure if all the selected C series modules are supported by the LabVIEW Real-Time software version I am using. Where can I conveniently check for this information?
You can look the software support for CompactRIO, CompactDAQ, Single-Board RIO, R Series, and EtherCAT devices here. This document describes the range of software versions required for the aforementioned devices. See also the C Series Module Compatibility Chart for more information.
NI recommends that you always use the most recent software for your system when possible.
