PXI(e) Controller Video Resolution
Updated Aug 28, 2018
  • PXI Controller
I have a PXI(e) controller, and I am wondering what the video resolution is. How can I find this out?
Our PXI(e) controller's manual may not have the explicit video resolution, but you should be able to find the graphics card for the controller in there. Then you can look at the video resolution of that graphics card.
For example, if you are looking for the PXIe-8135 video resolution than you will first look at page 12 of it's manual. Here there is a block diagram showing you that the display ports are using the ATI Radeon E4690 Embedded GPU to drive the graphics (You can also find this at the bottom of page 12). Knowing this you can find the specs for the ATI Radeon E4690, and you will see as a note at the end it says, "Display resolutions up to 3840x2400 per display output, provided available memory or interface bandwidth are not oversubscribed."
