The Apache Foundation created a Java library that can extract the text from a PDF file, among other things, called PDFBox. You can download the latest version of PDFBox Command Line tool to call it within LabVIEW using the System Exec.vi. VI snippet that uses the PDFBox Command Line Tool is attached at the bottom of this article. To use it, simply browse to the PDFBox-app-x.x.x.jar file in the "Path to .jar" control, and browse to the PDF file you wish to convert to text in the "Path to PDF". A text file will be generated with the filename and text contents of the PDF file
Note: Java Development Kit (JDK) must be installed to use this Java library
