Synchronizing Analog and Encoder Counter Inputs
Updated Mar 25, 2026
  • I am trying to synchronize a counter input with multiple analog inputs, but I keep running into errors. I am trying to figure out if this is possible to do and if so, how.
  • How can I synchronize an analog input with an encoder measurement?
It is possible to synchronize counter and analog inputs. The Synchronous Analog and Encoder Inputs  tutorial provides an example VI that synchronizes counter and analog inputs using a Producer/Consumer architecture.
The example VI consists of a Front Panel that allows for configuration of all acquisition settings:
The Synchronization Explained  tutorial walks through different synchronization options available to the PXI(e) platform. Depending on the hardware, the different synchronization options can be utilized to synchronize counter and analog inputs.
