PXI(e) Controller Legacy USB Support Option Grayed Out In BIOS Settings
Updated Jul 29, 2026
  • PXI Controller
I'm modifying my PXI(e) controller's BIOS Boot Order, but the Legacy USB Support option is grayed out. I need to enable this option to boot from my USB to upgrade my BIOS.
Make sure that the Boot Option is set to Windows/Other OS instead of LabVIEW RT. This option can be changed in the controller's BIOS settings by pressing the Delete key as the device boots.
Note: You might need to reboot the system after modifying and saving this Boot Option setting.
