Measurement and Automation Explorer Showing Incorrect Name
Updated Jul 18, 2018
The name that is showing up in the left-hand side of MAX used to show the correct serial number, but now does not. How do I change this?
In MAX the name that appears on the left-hand side is the one that you insert as the Hostname. Change the Hostname and the name that appears on the left will change as well.
