You can use any compatible industrial protocol that LabVIEW has a driver for, such as NI-Industrial Communication for Ethernet/IP, NI-Industrial Communication for EtherCAT and MODBUS Communication Palette available through the LabVIEW Datalogging and Supervisory Control Module. You can check for the commands available by referring to the manuals below:
