Where to Find LabVIEW Examples for USRP X310
Updated Mar 27, 2025
  • USRP X310
  • NI-USRP
I have an Ettus Research USRP X310 and would like to use it with LabVIEW. Where can I find some LabVIEW example codes for the same ?
As mentioned in the readme file, NI-USRP drivers for LabVIEW in Windows support the X310 board. All USRP LabVIEW examples (found at Start»All Programs»National Instruments»NI-USRP»Examples) can hence be used with USRP X310.
NI-USRP drivers for LabVIEW in Windows are also compatible with X300, N200, N210 Ettus Research USRP boards with TwinRX, UBX, CBX, CBX-120, WBX, WBX-120, SBX, SBX-120, XCVR2450 daughterboards. Other daughterboards may also be compatible, but they have not been tested.
