Slow FPGA Loop Rate when Taking Temperature Measurements on CompactRIO
Updated Mar 27, 2023
  • NI-9212
  • CompactRIO Controller
  • LabVIEW FPGA Module
  • LabVIEW Real-Time Module
I am acquiring temperature with the NI-9212 on my CompactRIO-9063's FPGA. I place an I/O Node inside a While Loop and my loop rate seems very slow, even though I set the FPGA to its 40 MHz clock. Why is this happening?
The FPGA loop speed is dictated by how fast the sampling rate of your module is. Temperature modules in general have very slow sampling rates, so it is slowing down your loop. Consider taking temperature measurements on the Real-Time Operating System of your CompactRIO.
