Can I Use the CB-68PL/ CB-68LPR Connector Blocks with My PXIe-7857R Module?
Updated Aug 9, 2018
  • PXIe-7857
I have a PXIe-7857R device. Can I use the NI CB-68LP ot the NI CB-68LPR connector blocks to create connections with my Reconfigurable I/O Module?
The National Instruments CB-68LP and CB-68LPR are unshielded I/O accessories with 68 screw terminals or easy signal connection to a National Instruments 68-pin DAQ device. However the PXIe-7857R requires noise rejecting and shielded I/O connector blocks both for the DIO and on the MIO connectors. Please check the user manual for detailed options on connection accessories.
