Error: -1950679023 When Deploying to Target and Using Network Shared Variables
Updated May 5, 2025
  • Distributed System Manager
  • TestStand
When I deploy the sequence. the client shows the following error when accessing shared variables:
Error -1950679023 occurred at an unidentified location
Possible reason(s):
LabVIEW: (Hex 0x8BBB0011) The process specified in the binding URL does not exist. Ensure that all shared variables are deployed and the variable identifier URL is correct.
Here you can see an image of the error explanation:
Please refer to the article Troubleshooting Network-Published Shared Variables, and check the steps mentioned there to discard the issue coming from any of the sources explained there.
If this does not solve the issue, contact Support.
