Is the CAN Port on the sbRIO-9687 Programmable?
Updated Jul 17, 2018
  • sbRIO-9687
  • sbRIO-9607
  • Does the sbRIO-9687's CAN port allow for both sending and receiving of CAN data?  Can you use it to issue commands programmatically?
  • Is the CAN port on the sbRIO-9687 limited to use with inverters?  Can I use it with other CAN devices, or do those need to be wired directly to the sbRIO-9687?
The sbRIO-9687's CAN port is directly connected to the sbRIO-9607's CAN port.  It is therefore the same port as the sbRIO-9607's; it is fully programmable by the sbRIO.
