Is It Possible to Acquire And Generate in The Same VI with DAQmx?
Updated Jul 17, 2018
I need to have two DAQmx task in the same VI, 1 to acquire and 1 to generate: is it possible?
Yes you can acquire and generate with DAQmx in the same VI, but (in the case of a continuos generation or acquisition) it is better to put each task in a different while loop.
