The
Indexing tunnel mode is building an array from the values passed out of the loop after each iteration. This will cause an error when the sinking terminal expects values that are not arrays. The terminal on the loop should be changed to
Last Value instead of
Indexing. Accomplish this by right-clicking the node and selecting the
Last Value option in the
Tunnel Mode menu.
