The IC's primary Ethernet port is part of a separate Network Identification Controller (NIC) than the other four Ethernet ports. As such, the primary port and the other four ports cannot belong on the same subnet. If the cDAQ is assigned a Static IP on the same subnet as the primary Ethernet port, you will need to configure the address to be on a new subnet on the IC . You will also need to set the IC's port connected to the cDAQ to Stati c to resolve this error.
A valid service agreement may be required, and support options vary by country.
