Error -1074384758 When Using A USB-8472 With The NI-XNET Compatibility Layer For NI-CAN
Updated Aug 22, 2018
  • USB-8472
  • NI-XNET
  • NI-CAN
I enabled the NI-XNET Compatability Layer For NI-CAN to use with my USB-8472. When I try to run the NI example CAN Input Stream VI I see "Error -1074384758 occurred at XNET Create Session".
The USB-8472 hardware is only compatible with the NI-CAN driver. The CAN Input Stream VI example uses the NI-XNET API. The NI-XNET Compatibility Layer For NI-CAN is able to interpret code built using the NI-CAN API for NI-XNET compatible hardware. This feature is not able to run NI-XNET code on NI-CAN hardware. To use the USB-8472, use only the NI-CAN API.
The final update to NI-CAN is version 17.0. This driver is supported up to LabVIEW 2017. The use of this driver will not be supported in versions 2018 and on.
