PXI Chassis Not Showing up in Measurement & Automation Explorer (Max)
Updated Jul 13, 2018
  • PXIe-8399
  • PCIe-8398
  • PXIe-8394
My PXI Chassis is not showing up in NI Measurement & Automation Explorer (NI-MAX), I'm using an MXI  PCIe card 8398. I have changed to a different slot, and the device is recognized on the Windows Device Manager, all NI Services are running, I have updated the BIOS and downloaded all the newest drivers, and the LED status on both cards are solid amber.
I have tried with a different computer with the same result and have tried the MXI Compatibility And Connectivity Troubleshooting Guide.
When you connect the MXI-Express cables, each end can be connected to either card, but make the connectors are not plugged into the card inverted. The connectors will physically fit, but the electrical connections will not match. Furthermore, if you connect the cables with the connectors inverted, the card could be damaged.
  • The MXI-Express Gen-3 x16 connectors are modular and can be cabled in several configurations. The hardware makes the configurations without user intervention.
  • The configuration mechanism requires PCI Express cables, not the connector-compatible cables that other standards use.
  • When multiple cables are used for a single link, the cables must be the same length.
  • You could connect MXI-Express x8 cables to both MXI-Express Gen-3 x16 modules.
  • The Cables have no polarity.
