Complex images are typically created when performing a fast fourier transform (FFT) on an image. Pixels in a complex image consist of a real component and an imaginary component. The complex image type can only be saved in AIPD format (internal file format), a National Instruments image data type that cannot be read by other programs. It is possible to save and read AIPD file in LabVIEW. To read the complex images with non-LabVIEW application, you can convert the complex image type into a regular image.
To convert a complex image type to use as a regular image, you can input the complex image into the IMAQ ComplexPlaneToImage VI, which can extract the Real, Imaginary, Magnitude, or Phase planes as a regular image that you can save in standard image formats such as BMP, JPEG, or PNG. See the following document for more information on the IMAQ ComplexPlaneToImage VI: NI Vision 2011 for LabVIEW Help: IMAQ ComplexPlaneToImage VI.
Another possible workaround is to programmatically take a screenshot of the image display and save it to file. This will not contain any complex information, but it can be saved to a BMP, JPEG, or PNG file. This workaround is shown in the figure below, and an example is posted here: Developer Zone Example: Save Complex Image to File.
