There are two ways in which you can change this state:1) You can set this value in the configuration for the counter output task.LabVIEW:ANSI C: Use the Events >> Counter Output Event >> Toggle >> Idle State property.2) You can do a reset of the device in LabVIEW. This takes the digitial lines to the power up states, you can additionally modify this power-up states .
