Archived:Change Axis Labels on a Waveform Chart in SignalExpress
Updated May 21, 2020
National Instruments does not actively maintain this document.
  • SignalExpress
How can I change axis labels on my Waveform Chart in NI SignalExpress?
To rename X or Y labels on Waveform Chart follow this procedure:
  1. Right-click on the choosen Waveform Graph in a Data View tab.
  2. Select Properties.
  3. In Display Properties window navigate to Scales tab.
  4. Select corresponding axis from pull-down menu.
  5. Change axis tittle by setting new value in Name property.
The default Y-axis name is defined by input channel type.
The default X-axis name is defined by time domain.
